Date/Time: Thu, 02 Apr 2026 19:10:27 +0000
Large Volume Trade Indicator Alerts
View Count: 793
| [2025-12-21 15:54:07] |
| User203631 - Posts: 26 |
I use the large volume indicator on my chart, and I need help setting up the audio alert every time there is a bubble of 50 and above even if its multiples times in the same 5min candle. my large volume indicator threshold is 35 and want alerts for 50 and above. when i go to the alert settings and input SG1>50, i only get one alert per candle. Thank you |
| [2025-12-21 18:41:24] |
| Sierra_Chart Engineering - Posts: 23413 |
For this you need to use the Alert functionality which is part of the Time and Sales window: Time and Sales Window Otherwise, it would be impossible, using the Simple Alerts on the Large Volume Trade Indicator study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-21 18:42:13
| [2025-12-21 18:47:01] |
I was primarily using the time and sales windows until I found a solution for the large volume trade indicator but I’ll go back to it. I closed the time and sales window this past trading week and noticed I don’t get the alerts, does the time and sales window need to be opened to receive the audio alerts?
| [2025-12-21 19:38:58] |
Yes it does make sense the Time and Sales window needs to be open for those alerts to function. Otherwise, the data does not get processed.
