Date/Time: Wed, 27 Nov 2024 22:28:16 +0000
Joining intraday data
View Count: 914
[2014-10-17 21:46:28] |
EuropeanTrader - Posts: 290 |
Hi, what does it mean "Use rollover rules for transition" on the menu here: http://www.sierrachart.com/index.php?page=doc/doc_JoinIntradayData.php Thanks |
[2014-10-18 02:54:17] |
We have updated the documentation explaining that option. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_JoinIntradayData.php#Join It is explained in the first section. Reload the page for the updated content. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
