Date/Time: Wed, 27 Nov 2024 22:53:30 +0000
Forced disconnect, cant login
View Count: 973
[2014-10-17 04:03:19] |
User021827 - Posts: 174 |
After updating tonight due to TTnet AMP . I cannot connect, log says forced logoff. shane |
[2014-10-17 04:09:00] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-17 04:14:34] |
It is now working. Took a couple of restarts. good now |
[2014-10-17 04:21:03] |
OK good.
