Date/Time: Wed, 27 Nov 2024 22:35:59 +0000
EUR/USD chart reports non existent long position. IB shows none.
View Count: 1037
[2014-10-16 19:53:23] |
Demi1201 - Posts: 68 |
Hello, SC shows me in a long EUR/USD position which is non existent. Can you suggest how to reset the software? Thank you, Dem |
[2014-10-16 20:05:55] |
Refer to help topic 80: Http://www.sierrachart.com/index.php?page=doc/helpdetails80.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-20 11:47:36] |
Thank you for your answer. I need to have Order Fill Calculated positions because I have an advisor account. When I check Display Order Fill Calculate Positions the long position in EUR/USD reappears. I was wondering if I can erase a file in the Sierra Chart directory to reset that position. Thank you, G Biondi |
[2014-10-21 08:44:44] |
Yes. Here is the documentation for this: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ClearingtheLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-21 08:45:11
