Date/Time: Wed, 27 Nov 2024 22:31:37 +0000
Bar #
View Count: 948
[2014-10-16 19:43:18] |
User20702 - Posts: 13 |
In a spreadsheet I want to Know what bar # I am on starting with 00:00:00 as bar 1. Can this be done and can you give me some code for it? Thanks Dave |
[2014-10-17 03:10:35] |
You can get this information by adding the Bar Numbering study to the chart.
