Date/Time: Wed, 27 Nov 2024 22:47:23 +0000
GER30 Historical Daily Data wrong
View Count: 1036
[2014-10-16 09:33:43] |
tomtom - Posts: 53 |
Hi, the GER30 Historical Data is wrong starting October 2002 - Dezember 2006 , data days are from tuesday to saturday starting January 2007 - 17 April 2009 candlesticks only 4 Days every week starting 18 April 2007 all Date fine please fix it thanks |
[2014-10-16 15:09:48] |
We do not see how we can correct this. This was the original data we got from FXCM. We do not have another source for this CFD data.
[2014-10-16 20:59:05] |
But when Data not correct they have no sense, if it possible to ask FXCM ?
[2014-10-17 22:42:31] |
We do not think this will help and it is too involved of a process. There is a better solution. Open a Historical Daily chart for the symbol DYY0. This will give you the cash market for the German DAX. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-17 22:45:54
[2014-10-18 02:05:56] |
AndyL - Posts: 119 |
Is there intraday and realtime data for this symbol also somehow available?
[2014-10-18 03:37:11] |
Yes , through the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
