Date/Time: Wed, 27 Nov 2024 22:30:04 +0000
instances of SC
View Count: 975
[2014-10-16 08:43:43] |
ripsdips - Posts: 143 |
May I have 2 instances of SC that I pay for with no data or trade services aside from the SC/FXCM one and then a 3rd instance with a trade service? And if I use TD Ameritrade can I use there futures symbols with SC? Thanks
[2014-10-16 10:24:31] |
user58907 - Posts: 83 |
Yes you can. http://www.sierrachart.com/index.php?page=doc/MultipleServices.html |
[2014-10-16 16:29:40] |
Refer to the documentation for this here: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html You cannot get futures data from TD Ameritrade. Refer to the information about this here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
