Date/Time: Thu, 28 Nov 2024 00:49:30 +0000
how to make an alert for the new range bar
View Count: 1154
[2014-10-16 02:49:13]
User47480 - Posts: 6
[2014-10-16 17:47:36]
vegasfoster - Posts: 444
Are you asking for an alert every time a new bar is formed?
[2014-10-17 01:04:13]
yes, i want to receive an alert when an new range bar is formed.
[2014-10-17 03:11:17]
You can get an alert when a new bar as added to the chart, by using the Countdown Timer study. Refer to the documentation for it in Technical Studies Reference.
[2014-10-22 12:45:46]
no, i use the range bar. so it is impossible to use the countdown time study
[2014-10-23 01:47:23]
Why is it impossible to use the Countdown Timer study in this case?
