Date/Time: Wed, 27 Nov 2024 22:47:37 +0000
Study/Price Overlay
View Count: 924
[2014-10-15 21:34:31] |
QnReally - Posts: 181 |
Is the source code for Study/Price Overlay study available? I would love to see the source code for that study unless you have some proprietary code in there. Thanks. |
[2014-10-16 05:34:56] |
Certainly nothing proprietary, but it is not in a format which is shareable.
[2014-10-17 16:10:27] |
I used this study to overlay the main graph of a chart with Renko Bar (in ticks) periodicity with a Graph Draw Type of Renko Brick with Wicks onto another chart with Volume Per Bar periodicity. The overlay's candles don't match the source chart bar per per. I got block candles as opposed to candles with wicks some of the times. The highs and lows of the bars are correct though. I was just wondering if this is by design. Also, I was looking at the study's subgraphs and I see SG22 as Renko Open and SG23 as Renko Close. Are these different from Open and Close? This information might help me with a study I am working on. Thanks. |
[2014-10-17 22:32:00] |
Yes, these are different. Refer to the Renko Bar Charts documentation here: http://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
