Date/Time: Wed, 27 Nov 2024 22:33:32 +0000
Equity Index Time Lag
View Count: 842
[2014-10-15 13:46:25] |
MsJackson - Posts: 27 |
I'm noticing significant time lag on the equities. Using OEC. Is it coming from their connection?
[2014-10-15 13:52:02] |
User600013 - Posts: 1 |
I see the same thing on ES. Charts look awful. When I try to reload the chart, I get duplicate bars and time at the bottom goes backwards sometimes. Not usable at all.
[2014-10-15 16:42:57] |
If you are using OEC, this is an OEC problem. This has been a long-standing problem that they have not been able to solve. It simply is not good. Have a look at using another supported trading service: https://www.sierrachart.com/index.php?page=doc/data.php We reloaded the historical data for OEC in case there were any data errors or missing data. We did see some indication of this. Therefore, follow the instructions in help topic 2.1.2 to re-download the data to correct any errors: https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
