Date/Time: Wed, 27 Nov 2024 22:38:35 +0000
Intraday stock data
View Count: 1065
[2014-10-15 05:49:10] |
cmb999 - Posts: 211 |
Hello, i just subscribed to stock exchanges through SC datafeed. can get daily, weekly chart for IBM, but hourly gives mesg: Unknown symbol
[2014-10-15 06:05:11] |
What is Global Settings >> Data/Trade Service Settings >> Service set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-15 11:44:48] |
CQG Trading. Allow support for Sierra Chart Data Feeds is checked,
[2014-10-15 17:24:34] |
We had to set up the symbol mapping for this. This has now been done. Update the Symbol Settings following the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
