Date/Time: Wed, 26 Feb 2025 19:59:35 +0000
Settings for Point & Figure Chart
View Count: 2261
[2014-10-15 05:43:20]
ged - Posts: 233
Wyckoff's Point & Figure charts don't function on the basis of a bar interval, but rather on the basis of the box (tick/point) size, and the number of reversal points selected, generally 3 or 5 (points).
Sierra Chart point and figure charts display different results depending on what bar interval (1m; 3m; 5m; 15m; etc) has been selected for the chart.
My question is: Is there a way I can effectively set up a point and figure chart for intraday trading that does not produce results that are effected by a bar interval?
Thanks very much.
[2014-10-17 04:15:13]
To do this you need to use Reversal Bars:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#ReversalBar
And not the Point and Figure Chart study.
Date Time Of Last Edit: 2014-10-17 04:15:36
[2021-06-01 23:54:38]
58LesPaul - Posts: 429
ged, Did you ever get a P&F chart or a reversal chart to look like the Wyckoff P&F chart?
