Date/Time: Wed, 27 Nov 2024 22:41:05 +0000
Continuous chart globex future
View Count: 900
[2014-10-14 16:43:10] |
cmb999 - Posts: 211 |
Hello, trying to construct a continuous chart for CME globex Nikkei (NY) on SC datafeed. I have downloaded sept. and jun history. I have 'volume-based back-adjusted' selected, but it does not link the contracts on a daily/ weekly chart. settings work great for ES, etc.
[2014-10-15 03:58:16] |
We had to add rollover rule settings. Follow the instructions here to update the symbol settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings When that is done go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
