Date/Time: Wed, 27 Nov 2024 20:31:04 +0000
CHART HEADER - WANT TO SHOW CURRENT (RUNNING) RANGE OF TWENTY-FOUR HOUR SESSION
View Count: 908
[2014-10-14 05:39:48] |
User41636 - Posts: 35 |
In the chart header at the top of each chart, is it possible to show the current range for the twenty-four hour session? Stock index futures traders, for example, know the significance of the high and low of the evening session right before the day session opens. If I'm correct, the high and low that can be displayed in the chart header at present is for the latest bar only - which can be readily displayed elsewhere. |
[2014-10-14 06:11:58] |
What you are looking for can be found in Window >> Current Quote Window.
