Date/Time: Wed, 27 Nov 2024 22:26:11 +0000
[Locked] - Cannot view Live trade activity
View Count: 1124
[2014-10-13 15:18:33]
User120827 - Posts: 77
Hi
I can only look at sim trade activity.
It wont let me select live account and live instrument activity.
It keeps defaulting back to sim and wont let me select non simulated.
Have you seen this before ?
shane
[2014-10-13 16:30:04]
This means you have not selected the correct symbol and correct Trade Account at the top of the Trade Activity Log.
[2014-10-13 17:52:52]
As I stated previously, it wont let me select the correct trade account and correct symbol.
If I select it, it goes back to sim in the accounts pull down selector and simulated in the pull down selector for sim, non-sim.
shane
ps
after restarting Sierra , I can now select "all" accounts and "all" symbols with "non sim" which shows live trades. Still unable to select individual symbols or individual accts.
will restart again
Date Time Of Last Edit: 2014-10-13 18:03:09
[2014-10-13 18:05:40]
A restart is not necessary.
Tell us what symbol you are selecting which causes the order fill source to go to Simulated.
[2014-10-13 18:21:02]
either TF FMZ0014! or CLX4-NYMEX
Those were the only one I traded today.
Perhaps it is the rithmic connection.
otherwise I can view all symbols and all accounts under non-simulated.
I just cant select an individual symbol.
[2014-10-13 19:45:59]
So when you select one of those symbols, the list box at the top of the Trade activity Log that contains the order activity sources is set to Simulated?
Not sure it matters, but update Sierra Chart to the current version.
Date Time Of Last Edit: 2014-10-13 19:46:57
[2014-10-13 19:51:21]
it switches back to sim if I try and select a symbol.
If I leave it on " All " symbols, then it will stay on the live account and I can view activity of all the symbols.
If I try to select one symbol, then it switches to sim in the top boxes ( drop down menu boxes )
weird , right ?
I will update
thanks
shane
[2014-10-13 20:00:50]
It is the same after upgrading.
[2014-10-13 20:07:48]
When you see it switch to Simulation attach an image of the top of the Trade Activity Log so we can look at it.
Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
You can also privately attach files.
[2014-10-14 11:54:21]
on left I have all symbols selected with live account.
on right I select crude oil symbol and it switches to simulated and sim account
imageUntitled.jpg / V - Attached On 2014-10-14 11:52:38 UTC - Size: 348 KB - 362 views
[2014-10-14 16:24:28]
This makes sense because the symbol has [Sim] in front of it.
[2014-10-14 16:49:51]
User021827 - Posts: 174
yes but I did not select sim, thats the problem
That happens when I select live, it just defaults back to sim if i try to select individual symbol while i have live account selected.
Again, I cannot view the activity of individual symbols under live account. I can only view live activity of all symbols.
thanks
shane
[2014-10-14 17:41:30]
What this means is there is no non-simulated trade activity for a symbol if you do not see [Sim] in front of it.
