Date/Time: Wed, 27 Nov 2024 20:39:24 +0000
Map Alerts Log from Alerts Manager to a chart using a study?
View Count: 951
[2014-10-13 13:34:46]
cgarrad - Posts: 27
Real time results differ from historical.
Can this be done?
[2014-10-13 17:01:44]
We are not understanding at all the question.
[2014-10-13 17:42:00]
cgarrad - Posts: 27
Sorry, badly worded alright!
I'm looking to map the results from the real time alerts log from Alerts Manager to a chart. (i.e. leave it run for 24 hours and use that data)
It is to allow me to compare them to the results which I can observe using historical data.
[2014-10-13 19:23:58]
Not sure what you mean by "map the results".
The Alerts Log does contain all of the alerts which have occurred.
[2014-10-13 19:37:02]
cgarrad - Posts: 27
The same way that a spreadsheet study can be added under the chart to chart region 2 and the spreadsheet data can be viewed in a very clear format
I want to do the same using the data from the real time alerts log and add it to chart region 3 and compare them.
I will give a visual representation of real time vs historical results (assuming you have ran SC in realtime and acquired some alerts)
[2014-10-13 19:43:19]
This is not supported.
We recommend using the Color Bar Based on Alert Condition study.
