Date/Time: Wed, 27 Nov 2024 20:50:33 +0000
Adjust Trig and Trail Offset
View Count: 993
[2014-10-13 09:59:05]
AKR - Posts: 523
Request for a feature. Very nice to have, nothing is a must...
It would be great if one could adjust the Trig Offset and Trail Offset (and prob also BE offsets) once an order is placed directly on the order line in the DOM (just like now you can adjust the quantity).
The thing is that I like to adjust the Trig Offset for a order depending on the stop. Of course I can go to "Targets" and adjust there. But this would often be too slow and is less convenient. I would need to define a separate bracket for each number of stop points. Sometimes there also could be a fill of the initial order and then this would not be possible at all anymore.
thx
