Date/Time: Wed, 27 Nov 2024 20:34:04 +0000
QQQ AND SPY INTERACTIVE BROKERS
View Count: 1757
[2014-10-13 06:16:10] |
User22153 - Posts: 46 |
Hello Support, I am trying to add QQQ symbol to the quote board but it doesn't recognise the symbol. Is there additional letters I need to put after the QQQ to download data from IB? Same for SPY ETF. Thanks. |
[2014-10-13 06:32:50] |
What this means is that you cannot use these simple symbols with Interactive Brokers. You need to use the complete symbol format which specifies the Exchange and primary exchange: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
