Date/Time: Wed, 27 Nov 2024 20:46:30 +0000
STOCHASTIC CROSSOVER SYSTEM
View Count: 1572
[2014-10-13 03:55:07] |
User41636 - Posts: 35 |
CANNOT GET ABOVE STUDY TO COME UP ON ANY INTRADAY CHART. IS IT AN ADDITIONAL FEATURE AT EXTRA COST?
[2014-10-13 04:03:56] |
The study will only display arrows on the chart bars. Do you see those?
[2014-10-13 05:14:34] |
Absurd. Whoever came up with the idea of displaying this study only with arrows on the chart bars has rendered worthless an otherwise extremely useful study. Why not display it like your other stochastic studies? Downright silly.
[2014-10-13 06:25:45] |
You also need to add the Stochastic - Slow study to the chart and set the corresponding Inputs the same. A study can only be displayed within a single chart region. So it is not possible to have a stochastic study that also displays arrows on a chart bar within a single study. So you need to have 2 studies on the chart. It is extremely common among our users to work with studies that only display arrows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-13 06:27:22
