Date/Time: Fri, 22 Nov 2024 13:02:30 +0000
error when placing CLM3 order from chart
View Count: 1709
[2013-05-13 12:24:42] |
infpz - Posts: 826 |
Trade Order Error - Unable to find wire contract object. Internal Order ID: 465. Symbol: CLM3 | 2013-05-13 07:03:41 Trade Order Error - Unable to find wire contract object. Internal Order ID: 466. Symbol: CLM3 | 2013-05-13 07:04:44 |
[2013-05-13 15:05:42] |
Checking on this.
[2013-05-13 16:15:37] |
Not sure why this is happening, but it appears be related to the newer TransAct API software. We did make a change that hopefully should workaround it. Please update to version 974 by selecting Help >> Download Prerelease.
