Date/Time: Wed, 27 Nov 2024 20:41:32 +0000
18 -24 Second Delay Before Candle Next Candle Starts
View Count: 844
[2014-10-10 16:54:16] |
User428971 - Posts: 26 |
Hi, I've noticed that on my charts there is a 18-24 second delay before the next candle start. For example, on a 2 or 5 min chart, I have seen over and over, when the current candle countdown clock reaches 0:00 that same candle will keep changing price for 18-24 seconds, then the next candle starts at, for a 2 min chart, 1:42 or right around there by a few seconds. There are contracts being traded. I think if there are no contracts being traded then it would act like this, but this happens consistently all day. I'm not sure how long it has been doing this because I have only started to concentrate on smaller charts. Also I am running version 1187 and have high speed internet. Thank you. |
[2014-10-10 17:01:32] |
Refer to help topic 38: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
