Date/Time: Wed, 27 Nov 2024 20:41:14 +0000
HOW TO SCROLL HORIZONTALLY ACROSS CHART WITHOUT VERTICAL SCALE EXPANDING AND COMPRESSING
View Count: 1380
[2014-10-10 12:48:42] |
User41636 - Posts: 35 |
IS THERE A WAY TO SCROLL BACK AND FORTH HORIZONTALLY ALONG A CHART WITHOUT THE VERTICAL SCALE ALWAYS ADJUSTING (EXPANDING AND COMPRESSING) AS THE PRICE RANGE (ON Y-AXIS) WIDENS AND NARROWS?
[2014-10-10 15:33:37] |
Sort of. You can try using the Constant Range Scale Range type: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
