Date/Time: Wed, 27 Nov 2024 20:40:31 +0000
Bid Ask Volume Bars issue
View Count: 950
[2014-10-10 10:03:24] |
User11942 - Posts: 298 |
Hi SC team, I tried to set up a Bid Ask Volume Bars chart but it failed to work properly. Bars do not reflect bid/ask volume difference, they always have the same size representing bid and ask volumes (like if ask and bid volumes are always equal). Please see screenshot attached. What could possibly go wrong? Nothing is said in the documentation, but are there any settings I should adjust? Thanks. |
CL-201411-NYMEX [M] 1 Min #7 2014-10-10 05_11_45.001.png / V - Attached On 2014-10-10 09:39:23 UTC - Size: 72.89 KB - 371 views |
[2014-10-12 23:02:43] |
This will be solved in the next release.
