Date/Time: Wed, 27 Nov 2024 20:49:29 +0000
scroll
View Count: 1242
[2014-10-09 14:23:17]
User84098 - Posts: 5
Is there any way to scroll from one chartbook to the next without having to click on each one----a shortcut?
[2014-10-09 15:42:59]
Sierra Chart - Max - Posts: 5732
Yes, there are Keyboard Shortcut to change chartbooks. The default keys for changing chartbooks are F7 and F8.
To view and customize the Keyboard Shortcuts, refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeKeyboardShortcuts
To find the shortcut keys for changing chartbooks (Previous Chartbook / Next Chartbook) you will need to expand Window.
Sierra Chart Support
Date Time Of Last Edit: 2014-10-09 15:47:43
