Date/Time: Wed, 27 Nov 2024 22:49:58 +0000
Market replay issue
View Count: 2034
[2014-10-09 13:53:39] |
User48557 - Posts: 138 |
In my chartbook I have 2 identical charts, One is a 120 minute and the other is a 1 minunte . When I set up the replay and select "For all charts in chartbook". Then go to clock "play" both my charts go blank and nothing happens. My charts are also set to "continuous futures contract, volume based rollover. If that matters.
[2014-10-09 13:54:28] |
click*
[2014-10-09 16:53:24] |
Does the chart show a progress message indicating loading data or a message indicating that it is downloading Continuous Futures Contract data?
[2014-10-09 18:12:25] |
yes it does, it just stays like that. There were a few times when it didn't though. I noticed its only happening when I use continuous futures data
[2014-10-09 19:55:29] |
When this happens post a copy of the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-09 21:32:14] |
Log reviewed and removed.
Date Time Of Last Edit: 2014-10-10 16:21:27
[2014-10-10 16:22:24] |
We have reviewed the Message Log. Do the following: -Update Sierra Chart with Help >> Download Prerelease. -On the Message Log window press the Clear Log button. Press Yes. -Start the replay. -If you see the problem, then post the Message Log again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-15 13:44:03] |
Date rule based rollover from F.US.CLEN12 to next contract occurs at 2012-06-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEQ12 to next contract occurs at 2012-07-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEU12 to next contract occurs at 2012-08-20. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEV12 to next contract occurs at 2012-09-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEX12 to next contract occurs at 2012-10-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEZ12 to next contract occurs at 2012-11-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEF13 to next contract occurs at 2012-12-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEG13 to next contract occurs at 2013-01-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEH13 to next contract occurs at 2013-02-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEJ13 to next contract occurs at 2013-03-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEK13 to next contract occurs at 2013-04-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEM13 to next contract occurs at 2013-05-20. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEN13 to next contract occurs at 2013-06-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEQ13 to next contract occurs at 2013-07-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEU13 to next contract occurs at 2013-08-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEV13 to next contract occurs at 2013-09-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEX13 to next contract occurs at 2013-10-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEZ13 to next contract occurs at 2013-11-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEF14 to next contract occurs at 2013-12-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEG14 to next contract occurs at 2014-01-20. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEH14 to next contract occurs at 2014-02-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEJ14 to next contract occurs at 2014-03-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEK14 to next contract occurs at 2014-04-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEM14 to next contract occurs at 2014-05-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEN14 to next contract occurs at 2014-06-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEQ14 to next contract occurs at 2014-07-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEU14 to next contract occurs at 2014-08-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEV14 to next contract occurs at 2014-09-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEX14 to next contract occurs at 2014-10-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEX14 for the date range from 2014-09-19 to 0. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-15. | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] 2 Min #1 | Symbols used for continuous contract chart: | 2014-10-15 08:37:48 F.US.CLEN12 | 2014-10-15 08:37:48 F.US.CLEQ12 | 2014-10-15 08:37:48 F.US.CLEU12 | 2014-10-15 08:37:48 F.US.CLEV12 | 2014-10-15 08:37:48 F.US.CLEX12 | 2014-10-15 08:37:48 F.US.CLEZ12 | 2014-10-15 08:37:48 F.US.CLEF13 | 2014-10-15 08:37:48 F.US.CLEG13 | 2014-10-15 08:37:48 F.US.CLEH13 | 2014-10-15 08:37:48 F.US.CLEJ13 | 2014-10-15 08:37:48 F.US.CLEK13 | 2014-10-15 08:37:48 F.US.CLEM13 | 2014-10-15 08:37:48 F.US.CLEN13 | 2014-10-15 08:37:48 F.US.CLEQ13 | 2014-10-15 08:37:48 F.US.CLEU13 | 2014-10-15 08:37:48 F.US.CLEV13 | 2014-10-15 08:37:48 F.US.CLEX13 | 2014-10-15 08:37:48 F.US.CLEZ13 | 2014-10-15 08:37:48 F.US.CLEF14 | 2014-10-15 08:37:48 F.US.CLEG14 | 2014-10-15 08:37:48 F.US.CLEH14 | 2014-10-15 08:37:48 F.US.CLEJ14 | 2014-10-15 08:37:48 F.US.CLEK14 | 2014-10-15 08:37:48 F.US.CLEM14 | 2014-10-15 08:37:48 F.US.CLEN14 | 2014-10-15 08:37:48 F.US.CLEQ14 | 2014-10-15 08:37:48 F.US.CLEU14 | 2014-10-15 08:37:48 F.US.CLEV14 | 2014-10-15 08:37:48 F.US.CLEX14 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] 2 Min #1 | Waiting for 2 downloads for continuous contract chart to complete | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEN12 to next contract occurs at 2012-06-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEQ12 to next contract occurs at 2012-07-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEU12 to next contract occurs at 2012-08-20. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEV12 to next contract occurs at 2012-09-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEX12 to next contract occurs at 2012-10-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEZ12 to next contract occurs at 2012-11-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEF13 to next contract occurs at 2012-12-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEG13 to next contract occurs at 2013-01-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEH13 to next contract occurs at 2013-02-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEJ13 to next contract occurs at 2013-03-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEK13 to next contract occurs at 2013-04-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEM13 to next contract occurs at 2013-05-20. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEN13 to next contract occurs at 2013-06-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEQ13 to next contract occurs at 2013-07-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEU13 to next contract occurs at 2013-08-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEV13 to next contract occurs at 2013-09-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEX13 to next contract occurs at 2013-10-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEZ13 to next contract occurs at 2013-11-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEF14 to next contract occurs at 2013-12-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEG14 to next contract occurs at 2014-01-20. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEH14 to next contract occurs at 2014-02-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEJ14 to next contract occurs at 2014-03-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEK14 to next contract occurs at 2014-04-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEM14 to next contract occurs at 2014-05-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEN14 to next contract occurs at 2014-06-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEQ14 to next contract occurs at 2014-07-21. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEU14 to next contract occurs at 2014-08-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEV14 to next contract occurs at 2014-09-19. | 2014-10-15 08:37:48 Date rule based rollover from F.US.CLEX14 to next contract occurs at 2014-10-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:37:48 Checking Intraday data file for symbol F.US.CLEX14 for the date range from 2014-09-19 to 0. | 2014-10-15 08:37:48 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-15. | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2 | Symbols used for continuous contract chart: | 2014-10-15 08:37:48 F.US.CLEN12 | 2014-10-15 08:37:48 F.US.CLEQ12 | 2014-10-15 08:37:48 F.US.CLEU12 | 2014-10-15 08:37:48 F.US.CLEV12 | 2014-10-15 08:37:48 F.US.CLEX12 | 2014-10-15 08:37:48 F.US.CLEZ12 | 2014-10-15 08:37:48 F.US.CLEF13 | 2014-10-15 08:37:48 F.US.CLEG13 | 2014-10-15 08:37:48 F.US.CLEH13 | 2014-10-15 08:37:48 F.US.CLEJ13 | 2014-10-15 08:37:48 F.US.CLEK13 | 2014-10-15 08:37:48 F.US.CLEM13 | 2014-10-15 08:37:48 F.US.CLEN13 | 2014-10-15 08:37:48 F.US.CLEQ13 | 2014-10-15 08:37:48 F.US.CLEU13 | 2014-10-15 08:37:48 F.US.CLEV13 | 2014-10-15 08:37:48 F.US.CLEX13 | 2014-10-15 08:37:48 F.US.CLEZ13 | 2014-10-15 08:37:48 F.US.CLEF14 | 2014-10-15 08:37:48 F.US.CLEG14 | 2014-10-15 08:37:48 F.US.CLEH14 | 2014-10-15 08:37:48 F.US.CLEJ14 | 2014-10-15 08:37:48 F.US.CLEK14 | 2014-10-15 08:37:48 F.US.CLEM14 | 2014-10-15 08:37:48 F.US.CLEN14 | 2014-10-15 08:37:48 F.US.CLEQ14 | 2014-10-15 08:37:48 F.US.CLEU14 | 2014-10-15 08:37:48 F.US.CLEV14 | 2014-10-15 08:37:48 F.US.CLEX14 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2 | Waiting for 2 downloads for continuous contract chart to complete | 2014-10-15 08:37:48 HD Request # 2 | Downloading Intraday chart data for F.US.CLEZ12 to the file F.US.CLEZ12.scid. Service: nymex | 2014-10-15 08:37:48 HD Request # 2 | Download start Date-Time: 2012-11-16 13:29:58.0 | 2014-10-15 08:37:48 HD Request # 2 | Using server: scdf1.sierracharts.com port 10149 | 2014-10-15 08:37:48 HD Request # 3 | Downloading Historical Daily chart data for CLX14. Starting date: 2014-10-06. Service: cqg | 2014-10-15 08:37:48 Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-10-15 08:37:48 Historical data download counter reset. | 2014-10-15 08:37:48 HD Request # 3 | Requesting historical Daily data for CLX14 starting at 2014-10-05 | 2014-10-15 08:37:48 Socket (1140) | Connected. | 2014-10-15 08:37:48 HD Request # 2 | Sending historical data logon request message. | 2014-10-15 08:37:48 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2012-11-16 13:29:58. Record interval: 0. Symbol: CLZ2 | 2014-10-15 08:37:48 HD Request # 2 | Decompressing data. | 2014-10-15 08:37:48 HD Request # 2 | Receiving Intraday data for F.US.CLEZ12 starting at 2012-11-16 13:29:58 | 2014-10-15 08:37:48 Socket (1140) | Shutdown and closed. | 2014-10-15 08:37:48 The network socket for historical data has been closed. | 2014-10-15 08:37:48 HD Request # 2 | Received 1 record from 2012-11-16 13:29:58 to 2012-11-16 13:29:58 (0.0 seconds) and wrote 0 records for F.US.CLEZ12 | 2014-10-15 08:37:48 HD Request # 2 | Intraday download COMPLETE for F.US.CLEZ12. Completion time: 0s | 2014-10-15 08:37:48 Real-time Intraday chart data file updates started for F.US.CLEZ12 | 2014-10-15 08:37:48 HD Request # 3 | Receiving historical Daily data for CLX14 starting at 2014-10-06 | 2014-10-15 08:37:48 Writing historical Daily data for CLX14 to the file CLX14.dly | 2014-10-15 08:37:48 HD Request # 3 | Received 8 records from 2014-10-06 00:00:00 to 2014-10-15 00:00:00 (10.0 days) and wrote 8 records for CLX14 | 2014-10-15 08:37:48 HD Request # 3 | Daily download COMPLETE for CLX14. Completion time: 0s | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Download is complete for all contract months in chart. Proceeding with data load. | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Checking for volume based rollover dates. | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEN12 to F.US.CLEQ12 occurs at 2012-06-19 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEQ12 to F.US.CLEU12 occurs at 2012-07-19 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEU12 to F.US.CLEV12 occurs at 2012-08-20 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEV12 to F.US.CLEX12 occurs at 2012-09-19 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEX12 to F.US.CLEZ12 occurs at 2012-10-19 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEZ12 to F.US.CLEF13 occurs at 2012-11-15 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEF13 to F.US.CLEG13 occurs at 2012-12-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEG13 to F.US.CLEH13 occurs at 2013-01-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEH13 to F.US.CLEJ13 occurs at 2013-02-19 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEJ13 to F.US.CLEK13 occurs at 2013-03-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEK13 to F.US.CLEM13 occurs at 2013-04-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEM13 to F.US.CLEN13 occurs at 2013-05-20 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEN13 to F.US.CLEQ13 occurs at 2013-06-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEQ13 to F.US.CLEU13 occurs at 2013-07-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEU13 to F.US.CLEV13 occurs at 2013-08-16 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEV13 to F.US.CLEX13 occurs at 2013-09-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEX13 to F.US.CLEZ13 occurs at 2013-10-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEZ13 to F.US.CLEF14 occurs at 2013-11-19 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEF14 to F.US.CLEG14 occurs at 2013-12-17 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEG14 to F.US.CLEH14 occurs at 2014-01-17 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEH14 to F.US.CLEJ14 occurs at 2014-02-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEJ14 to F.US.CLEK14 occurs at 2014-03-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEK14 to F.US.CLEM14 occurs at 2014-04-21 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEM14 to F.US.CLEN14 occurs at 2014-05-19 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEN14 to F.US.CLEQ14 occurs at 2014-06-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEQ14 to F.US.CLEU14 occurs at 2014-07-18 | 2014-10-15 08:37:48 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEU14 to F.US.CLEV14 occurs at 2014-08-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Volume based rollover from F.US.CLEV14 to F.US.CLEX14 occurs at 2014-09-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Performing continuous futures contract back adjustment calculations. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN12 Open price on 2012-06-19 is 83.06. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ12 Open price on 2012-06-19 is 83.44. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN12 price difference to F.US.CLEQ12 is 0.38. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ12 Open price on 2012-07-19 is 90.08. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU12 Open price on 2012-07-19 is 90.35. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ12 price difference to F.US.CLEU12 is 0.27000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU12 Open price on 2012-08-20 is 96.36. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV12 Open price on 2012-08-20 is 96.64. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU12 price difference to F.US.CLEV12 is 0.28. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV12 Open price on 2012-09-19 is 95.49. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEX12 Open price on 2012-09-19 is 95.83. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV12 price difference to F.US.CLEX12 is 0.34. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEX12 Open price on 2012-10-19 is 92.04. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEZ12 Open price on 2012-10-19 is 92.48. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEX12 price difference to F.US.CLEZ12 is 0.44. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEZ12 Open price on 2012-11-15 is 86.36. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEF13 Open price on 2012-11-15 is 86.77. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEZ12 price difference to F.US.CLEF13 is 0.41. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEF13 Open price on 2012-12-18 is 87.45. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEG13 Open price on 2012-12-18 is 87.94. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEF13 price difference to F.US.CLEG13 is 0.49000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEG13 Open price on 2013-01-18 is 95.19. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEH13 Open price on 2013-01-18 is 95.65. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEG13 price difference to F.US.CLEH13 is 0.46000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEH13 Open price on 2013-02-19 is 95.97. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEJ13 Open price on 2013-02-19 is 96.39. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEH13 price difference to F.US.CLEJ13 is 0.41999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEJ13 Open price on 2013-03-18 is 93.26. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEK13 Open price on 2013-03-18 is 93.62. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEJ13 price difference to F.US.CLEK13 is 0.36000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEK13 Open price on 2013-04-18 is 86.39. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEM13 Open price on 2013-04-18 is 86.6. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEK13 price difference to F.US.CLEM13 is 0.20999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEM13 Open price on 2013-05-20 is 95.93. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN13 Open price on 2013-05-20 is 96.25. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEM13 price difference to F.US.CLEN13 is 0.31999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN13 Open price on 2013-06-18 is 97.93. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ13 Open price on 2013-06-18 is 98.16. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN13 price difference to F.US.CLEQ13 is 0.23. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ13 Open price on 2013-07-18 is 106.56. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU13 Open price on 2013-07-18 is 106.35. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ13 price difference to F.US.CLEU13 is -0.20999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU13 Open price on 2013-08-16 is 107.18. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV13 Open price on 2013-08-16 is 107.01. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU13 price difference to F.US.CLEV13 is -0.17. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV13 Open price on 2013-09-18 is 105.53. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEX13 Open price on 2013-09-18 is 104.77. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV13 price difference to F.US.CLEX13 is -0.75999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEX13 Open price on 2013-10-18 is 100.72. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEZ13 Open price on 2013-10-18 is 101. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEX13 price difference to F.US.CLEZ13 is 0.28. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEZ13 Open price on 2013-11-19 is 93. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEF14 Open price on 2013-11-19 is 93.64. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEZ13 price difference to F.US.CLEF14 is 0.63999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEF14 Open price on 2013-12-17 is 97.3. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEG14 Open price on 2013-12-17 is 97.54. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEF14 price difference to F.US.CLEG14 is 0.23999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEG14 Open price on 2014-01-17 is 94.17. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEH14 Open price on 2014-01-17 is 94.29. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEG14 price difference to F.US.CLEH14 is 0.12. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEH14 Open price on 2014-02-18 is 100.32. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEJ14 Open price on 2014-02-18 is 100.12. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEH14 price difference to F.US.CLEJ14 is -0.2. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEJ14 Open price on 2014-03-18 is 97.97. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEK14 Open price on 2014-03-18 is 97.46. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEJ14 price difference to F.US.CLEK14 is -0.50999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEK14 Open price on 2014-04-21 is 104.54. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEM14 Open price on 2014-04-21 is 103.7. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEK14 price difference to F.US.CLEM14 is -0.83999997. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEM14 Open price on 2014-05-19 is 102.13. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN14 Open price on 2014-05-19 is 101.68. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEM14 price difference to F.US.CLEN14 is -0.44999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN14 Open price on 2014-06-18 is 106.6. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ14 Open price on 2014-06-18 is 106.06. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEN14 price difference to F.US.CLEQ14 is -0.54000002. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ14 Open price on 2014-07-18 is 103.72. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU14 Open price on 2014-07-18 is 102.77. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEQ14 price difference to F.US.CLEU14 is -0.94999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU14 Open price on 2014-08-18 is 97.1. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV14 Open price on 2014-08-18 is 95.14. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEU14 price difference to F.US.CLEV14 is -1.96. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV14 Open price on 2014-09-19 is 92.97. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEX14 Open price on 2014-09-19 is 91.96. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: F.US.CLEV14 price difference to F.US.CLEX14 is -1.01. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEN12 is -1.71. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEQ12 is -2.0899999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEU12 is -2.3600001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEV12 is -2.6400001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEX12 is -2.9800003. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEZ12 is -3.4200003. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEF13 is -3.8300002. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEG13 is -4.3200002. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEH13 is -4.7799997. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEJ13 is -5.1999998. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEK13 is -5.5600004. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEM13 is -5.7700005. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEN13 is -6.0900002. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEQ13 is -6.3200006. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEU13 is -6.1100006. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEV13 is -5.9400005. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEX13 is -5.1800003. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEZ13 is -5.46. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEF14 is -6.1000004. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEG14 is -6.3400002. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEH14 is -6.46. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEJ14 is -6.2600002. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEK14 is -5.75. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEM14 is -4.9099998. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEN14 is -4.46. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEQ14 is -3.9200001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEU14 is -2.97. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] #2: Back adjust amount for symbol F.US.CLEV14 is -1.01. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Download is complete for all contract months in chart. Proceeding with data load. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Checking for volume based rollover dates. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEN12 to F.US.CLEQ12 occurs at 2012-06-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEQ12 to F.US.CLEU12 occurs at 2012-07-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEU12 to F.US.CLEV12 occurs at 2012-08-20 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEV12 to F.US.CLEX12 occurs at 2012-09-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEX12 to F.US.CLEZ12 occurs at 2012-10-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEZ12 to F.US.CLEF13 occurs at 2012-11-15 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEF13 to F.US.CLEG13 occurs at 2012-12-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEG13 to F.US.CLEH13 occurs at 2013-01-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEH13 to F.US.CLEJ13 occurs at 2013-02-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEJ13 to F.US.CLEK13 occurs at 2013-03-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEK13 to F.US.CLEM13 occurs at 2013-04-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEM13 to F.US.CLEN13 occurs at 2013-05-20 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEN13 to F.US.CLEQ13 occurs at 2013-06-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEQ13 to F.US.CLEU13 occurs at 2013-07-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEU13 to F.US.CLEV13 occurs at 2013-08-16 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEV13 to F.US.CLEX13 occurs at 2013-09-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEX13 to F.US.CLEZ13 occurs at 2013-10-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEZ13 to F.US.CLEF14 occurs at 2013-11-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEF14 to F.US.CLEG14 occurs at 2013-12-17 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEG14 to F.US.CLEH14 occurs at 2014-01-17 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEH14 to F.US.CLEJ14 occurs at 2014-02-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEJ14 to F.US.CLEK14 occurs at 2014-03-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEK14 to F.US.CLEM14 occurs at 2014-04-21 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEM14 to F.US.CLEN14 occurs at 2014-05-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEN14 to F.US.CLEQ14 occurs at 2014-06-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEQ14 to F.US.CLEU14 occurs at 2014-07-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEU14 to F.US.CLEV14 occurs at 2014-08-18 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Volume based rollover from F.US.CLEV14 to F.US.CLEX14 occurs at 2014-09-19 | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: Performing continuous futures contract back adjustment calculations. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN12 Open price on 2012-06-19 is 83.06. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ12 Open price on 2012-06-19 is 83.44. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN12 price difference to F.US.CLEQ12 is 0.38. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ12 Open price on 2012-07-19 is 90.08. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU12 Open price on 2012-07-19 is 90.35. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ12 price difference to F.US.CLEU12 is 0.27000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU12 Open price on 2012-08-20 is 96.36. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV12 Open price on 2012-08-20 is 96.64. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU12 price difference to F.US.CLEV12 is 0.28. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV12 Open price on 2012-09-19 is 95.49. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEX12 Open price on 2012-09-19 is 95.83. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV12 price difference to F.US.CLEX12 is 0.34. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEX12 Open price on 2012-10-19 is 92.04. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEZ12 Open price on 2012-10-19 is 92.48. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEX12 price difference to F.US.CLEZ12 is 0.44. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEZ12 Open price on 2012-11-15 is 86.36. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEF13 Open price on 2012-11-15 is 86.77. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEZ12 price difference to F.US.CLEF13 is 0.41. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEF13 Open price on 2012-12-18 is 87.45. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEG13 Open price on 2012-12-18 is 87.94. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEF13 price difference to F.US.CLEG13 is 0.49000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEG13 Open price on 2013-01-18 is 95.19. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEH13 Open price on 2013-01-18 is 95.65. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEG13 price difference to F.US.CLEH13 is 0.46000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEH13 Open price on 2013-02-19 is 95.97. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEJ13 Open price on 2013-02-19 is 96.39. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEH13 price difference to F.US.CLEJ13 is 0.41999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEJ13 Open price on 2013-03-18 is 93.26. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEK13 Open price on 2013-03-18 is 93.62. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEJ13 price difference to F.US.CLEK13 is 0.36000001. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEK13 Open price on 2013-04-18 is 86.39. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEM13 Open price on 2013-04-18 is 86.6. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEK13 price difference to F.US.CLEM13 is 0.20999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEM13 Open price on 2013-05-20 is 95.93. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN13 Open price on 2013-05-20 is 96.25. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEM13 price difference to F.US.CLEN13 is 0.31999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN13 Open price on 2013-06-18 is 97.93. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ13 Open price on 2013-06-18 is 98.16. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN13 price difference to F.US.CLEQ13 is 0.23. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ13 Open price on 2013-07-18 is 106.56. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU13 Open price on 2013-07-18 is 106.35. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ13 price difference to F.US.CLEU13 is -0.20999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU13 Open price on 2013-08-16 is 107.18. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV13 Open price on 2013-08-16 is 107.01. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU13 price difference to F.US.CLEV13 is -0.17. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV13 Open price on 2013-09-18 is 105.53. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEX13 Open price on 2013-09-18 is 104.77. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV13 price difference to F.US.CLEX13 is -0.75999999. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEX13 Open price on 2013-10-18 is 100.72. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEZ13 Open price on 2013-10-18 is 101. | 2014-10-15 08:37:49 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEX13 price difference to F.US.CLEZ13 is 0.28. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEZ13 Open price on 2013-11-19 is 93. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEF14 Open price on 2013-11-19 is 93.64. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEZ13 price difference to F.US.CLEF14 is 0.63999999. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEF14 Open price on 2013-12-17 is 97.3. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEG14 Open price on 2013-12-17 is 97.54. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEF14 price difference to F.US.CLEG14 is 0.23999999. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEG14 Open price on 2014-01-17 is 94.17. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEH14 Open price on 2014-01-17 is 94.29. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEG14 price difference to F.US.CLEH14 is 0.12. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEH14 Open price on 2014-02-18 is 100.32. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEJ14 Open price on 2014-02-18 is 100.12. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEH14 price difference to F.US.CLEJ14 is -0.2. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEJ14 Open price on 2014-03-18 is 97.97. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEK14 Open price on 2014-03-18 is 97.46. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEJ14 price difference to F.US.CLEK14 is -0.50999999. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEK14 Open price on 2014-04-21 is 104.54. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEM14 Open price on 2014-04-21 is 103.7. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEK14 price difference to F.US.CLEM14 is -0.83999997. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEM14 Open price on 2014-05-19 is 102.13. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN14 Open price on 2014-05-19 is 101.68. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEM14 price difference to F.US.CLEN14 is -0.44999999. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN14 Open price on 2014-06-18 is 106.6. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ14 Open price on 2014-06-18 is 106.06. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEN14 price difference to F.US.CLEQ14 is -0.54000002. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ14 Open price on 2014-07-18 is 103.72. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU14 Open price on 2014-07-18 is 102.77. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEQ14 price difference to F.US.CLEU14 is -0.94999999. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU14 Open price on 2014-08-18 is 97.1. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV14 Open price on 2014-08-18 is 95.14. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEU14 price difference to F.US.CLEV14 is -1.96. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV14 Open price on 2014-09-19 is 92.97. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEX14 Open price on 2014-09-19 is 91.96. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: F.US.CLEV14 price difference to F.US.CLEX14 is -1.01. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEN12 is -1.71. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEQ12 is -2.0899999. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEU12 is -2.3600001. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEV12 is -2.6400001. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEX12 is -2.9800003. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEZ12 is -3.4200003. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEF13 is -3.8300002. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEG13 is -4.3200002. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEH13 is -4.7799997. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEJ13 is -5.1999998. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEK13 is -5.5600004. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEM13 is -5.7700005. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEN13 is -6.0900002. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEQ13 is -6.3200006. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEU13 is -6.1100006. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEV13 is -5.9400005. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEX13 is -5.1800003. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEZ13 is -5.46. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEF14 is -6.1000004. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEG14 is -6.3400002. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEH14 is -6.46. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEJ14 is -6.2600002. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEK14 is -5.75. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEM14 is -4.9099998. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEN14 is -4.46. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEQ14 is -3.9200001. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEU14 is -2.97. | 2014-10-15 08:37:50 F.US.CLEX14 [CBV] 2 Min #1: Back adjust amount for symbol F.US.CLEV14 is -1.01. | 2014-10-15 08:37:50 CQG Trading | Starting real-time market data updates for: F.US.CLEX14. ID: 3 | 2014-10-15 08:37:50 CQG Trading | Sending symbol resolution request for F.US.CLEX14 | 2014-10-15 08:37:50 Intraday data recording state for symbol F.US.CLEX14 is set to pending. | 2014-10-15 08:37:50 HD Request # 4 | Downloading Intraday chart data for F.US.CLEX14 to the file F.US.CLEX14.scid. Service: cqg | 2014-10-15 08:37:50 HD Request # 4 | Download start Date-Time: 2014-10-15 08:17:31.0 | 2014-10-15 08:37:50 HD Request # 4 | Using server: ds5.sierracharts.com port 10149 | 2014-10-15 08:37:50 CQG Trading | Requesting market data trades for F.US.CLEX14 | 2014-10-15 08:37:50 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-10-15 08:37:50 Socket (1276) | Connected. | 2014-10-15 08:37:50 HD Request # 4 | Sending historical data logon request message. | 2014-10-15 08:37:50 Market data subscription status for F.US.CLEX14: Real-time data for instrument F.US.CLE (corresponding to ID = 1) are not allowed. | 2014-10-15 08:37:50 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-10-15 08:17:31. Record interval: 0. Symbol: F.US.CLEX14 | 2014-10-15 08:37:50 HD Request # 4 | Decompressing data. | 2014-10-15 08:37:50 HD Request # 4 | Receiving Intraday data for F.US.CLEX14 starting at 2014-10-15 08:17:31 | 2014-10-15 08:37:50 HD Request # 4 | Timestamp of first Intraday data file record written: 2014-10-15 08:17:32 | 2014-10-15 08:37:50 Socket (1276) | Shutdown and closed. | 2014-10-15 08:37:50 The network socket for historical data has been closed. | 2014-10-15 08:37:50 HD Request # 4 | Received 16151 records from 2014-10-15 08:17:31 to 2014-10-15 08:37:52 (20.4 minutes) and wrote 16147 records for F.US.CLEX14 | 2014-10-15 08:37:50 HD Request # 4 | Intraday download COMPLETE for F.US.CLEX14. Completion time: 0s | 2014-10-15 08:37:50 Real-time Intraday chart data file updates started for F.US.CLEX14 | 2014-10-15 08:37:50 Date rule based rollover from F.US.CLEN12 to next contract occurs at 2012-06-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEQ12 to next contract occurs at 2012-07-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEU12 to next contract occurs at 2012-08-20. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEV12 to next contract occurs at 2012-09-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEX12 to next contract occurs at 2012-10-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEZ12 to next contract occurs at 2012-11-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEF13 to next contract occurs at 2012-12-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEG13 to next contract occurs at 2013-01-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEH13 to next contract occurs at 2013-02-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEJ13 to next contract occurs at 2013-03-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEK13 to next contract occurs at 2013-04-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEM13 to next contract occurs at 2013-05-20. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEN13 to next contract occurs at 2013-06-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEQ13 to next contract occurs at 2013-07-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEU13 to next contract occurs at 2013-08-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEV13 to next contract occurs at 2013-09-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEX13 to next contract occurs at 2013-10-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEZ13 to next contract occurs at 2013-11-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEF14 to next contract occurs at 2013-12-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEG14 to next contract occurs at 2014-01-20. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEH14 to next contract occurs at 2014-02-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEJ14 to next contract occurs at 2014-03-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEK14 to next contract occurs at 2014-04-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEM14 to next contract occurs at 2014-05-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEN14 to next contract occurs at 2014-06-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEQ14 to next contract occurs at 2014-07-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEU14 to next contract occurs at 2014-08-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEV14 to next contract occurs at 2014-09-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEX14 to next contract occurs at 2014-10-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:39:10 Intraday data recording state for symbol F.US.CLEZ12 is set to pending. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEX14 for the date range from 2014-09-19 to 0. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-15. | 2014-10-15 08:39:10 Replay 100.0X: F.US.CLEX14 [CBV] 2 Min #1 | Symbols used for continuous contract chart: | 2014-10-15 08:39:10 F.US.CLEN12 | 2014-10-15 08:39:10 F.US.CLEQ12 | 2014-10-15 08:39:10 F.US.CLEU12 | 2014-10-15 08:39:10 F.US.CLEV12 | 2014-10-15 08:39:10 F.US.CLEX12 | 2014-10-15 08:39:10 F.US.CLEZ12 | 2014-10-15 08:39:10 F.US.CLEF13 | 2014-10-15 08:39:10 F.US.CLEG13 | 2014-10-15 08:39:10 F.US.CLEH13 | 2014-10-15 08:39:10 F.US.CLEJ13 | 2014-10-15 08:39:10 F.US.CLEK13 | 2014-10-15 08:39:10 F.US.CLEM13 | 2014-10-15 08:39:10 F.US.CLEN13 | 2014-10-15 08:39:10 F.US.CLEQ13 | 2014-10-15 08:39:10 F.US.CLEU13 | 2014-10-15 08:39:10 F.US.CLEV13 | 2014-10-15 08:39:10 F.US.CLEX13 | 2014-10-15 08:39:10 F.US.CLEZ13 | 2014-10-15 08:39:10 F.US.CLEF14 | 2014-10-15 08:39:10 F.US.CLEG14 | 2014-10-15 08:39:10 F.US.CLEH14 | 2014-10-15 08:39:10 F.US.CLEJ14 | 2014-10-15 08:39:10 F.US.CLEK14 | 2014-10-15 08:39:10 F.US.CLEM14 | 2014-10-15 08:39:10 F.US.CLEN14 | 2014-10-15 08:39:10 F.US.CLEQ14 | 2014-10-15 08:39:10 F.US.CLEU14 | 2014-10-15 08:39:10 F.US.CLEV14 | 2014-10-15 08:39:10 F.US.CLEX14 | 2014-10-15 08:39:10 Replay 100.0X: F.US.CLEX14 [CBV] 2 Min #1 | Waiting for 1 downloads for continuous contract chart to complete | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEN12 to next contract occurs at 2012-06-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEQ12 to next contract occurs at 2012-07-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEU12 to next contract occurs at 2012-08-20. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEV12 to next contract occurs at 2012-09-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEX12 to next contract occurs at 2012-10-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEZ12 to next contract occurs at 2012-11-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEF13 to next contract occurs at 2012-12-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEG13 to next contract occurs at 2013-01-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEH13 to next contract occurs at 2013-02-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEJ13 to next contract occurs at 2013-03-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEK13 to next contract occurs at 2013-04-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEM13 to next contract occurs at 2013-05-20. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEN13 to next contract occurs at 2013-06-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEQ13 to next contract occurs at 2013-07-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEU13 to next contract occurs at 2013-08-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEV13 to next contract occurs at 2013-09-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEX13 to next contract occurs at 2013-10-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEZ13 to next contract occurs at 2013-11-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEF14 to next contract occurs at 2013-12-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEG14 to next contract occurs at 2014-01-20. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEH14 to next contract occurs at 2014-02-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEJ14 to next contract occurs at 2014-03-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEK14 to next contract occurs at 2014-04-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEM14 to next contract occurs at 2014-05-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEN14 to next contract occurs at 2014-06-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEQ14 to next contract occurs at 2014-07-21. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEU14 to next contract occurs at 2014-08-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEV14 to next contract occurs at 2014-09-19. | 2014-10-15 08:39:10 Date rule based rollover from F.US.CLEX14 to next contract occurs at 2014-10-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:39:10 Intraday data recording state for symbol F.US.CLEZ12 is set to pending. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-15 08:39:10 Checking Intraday data file for symbol F.US.CLEX14 for the date range from 2014-09-19 to 0. | 2014-10-15 08:39:10 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-15. | 2014-10-15 08:39:10 Replay 100.0X: F.US.CLEX14 [CBV] #2 | Symbols used for continuous contract chart: | 2014-10-15 08:39:10 F.US.CLEN12 | 2014-10-15 08:39:10 F.US.CLEQ12 | 2014-10-15 08:39:10 F.US.CLEU12 | 2014-10-15 08:39:10 F.US.CLEV12 | 2014-10-15 08:39:10 F.US.CLEX12 | 2014-10-15 08:39:10 F.US.CLEZ12 | 2014-10-15 08:39:10 F.US.CLEF13 | 2014-10-15 08:39:10 F.US.CLEG13 | 2014-10-15 08:39:10 F.US.CLEH13 | 2014-10-15 08:39:10 F.US.CLEJ13 | 2014-10-15 08:39:10 F.US.CLEK13 | 2014-10-15 08:39:10 F.US.CLEM13 | 2014-10-15 08:39:10 F.US.CLEN13 | 2014-10-15 08:39:10 F.US.CLEQ13 | 2014-10-15 08:39:10 F.US.CLEU13 | 2014-10-15 08:39:10 F.US.CLEV13 | 2014-10-15 08:39:10 F.US.CLEX13 | 2014-10-15 08:39:10 F.US.CLEZ13 | 2014-10-15 08:39:10 F.US.CLEF14 | 2014-10-15 08:39:10 F.US.CLEG14 | 2014-10-15 08:39:10 F.US.CLEH14 | 2014-10-15 08:39:10 F.US.CLEJ14 | 2014-10-15 08:39:10 F.US.CLEK14 | 2014-10-15 08:39:10 F.US.CLEM14 | 2014-10-15 08:39:10 F.US.CLEN14 | 2014-10-15 08:39:10 F.US.CLEQ14 | 2014-10-15 08:39:10 F.US.CLEU14 | 2014-10-15 08:39:10 F.US.CLEV14 | 2014-10-15 08:39:10 F.US.CLEX14 | 2014-10-15 08:39:10 Replay 100.0X: F.US.CLEX14 [CBV] #2 | Waiting for 1 downloads for continuous contract chart to complete | 2014-10-15 08:39:10 HD Request # 5 | Downloading Intraday chart data for F.US.CLEZ12 to the file F.US.CLEZ12.scid. Service: nymex | 2014-10-15 08:39:10 HD Request # 5 | Download start Date-Time: 2012-11-16 13:29:58.0 | 2014-10-15 08:39:10 HD Request # 5 | Using server: scdf2.sierracharts.com port 10149 | 2014-10-15 08:39:10 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-10-15 08:39:10 Socket (1100) | Connected. | 2014-10-15 08:39:10 HD Request # 5 | Sending historical data logon request message. | 2014-10-15 08:39:10 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2012-11-16 13:29:58. Record interval: 0. Symbol: CLZ2 | 2014-10-15 08:39:10 HD Request # 5 | Decompressing data. | 2014-10-15 08:39:10 HD Request # 5 | Receiving Intraday data for F.US.CLEZ12 starting at 2012-11-16 13:29:58 | 2014-10-15 08:39:10 Socket (1100) | Shutdown and closed. | 2014-10-15 08:39:10 The network socket for historical data has been closed. | 2014-10-15 08:39:10 HD Request # 5 | Received 1 record from 2012-11-16 13:29:58 to 2012-11-16 13:29:58 (0.0 seconds) and wrote 0 records for F.US.CLEZ12 | 2014-10-15 08:39:10 HD Request # 5 | Intraday download COMPLETE for F.US.CLEZ12. Completion time: 0s | 2014-10-15 08:39:10 Real-time Intraday chart data file updates started for F.US.CLEZ12 | 2014-10-15 08:39:10 |
[2014-10-15 13:45:12] |
User48557 - Posts: 138 |
same issue. I am unable to backtest with more then 1 chart at a time
[2014-10-15 20:00:12] |
I also clicked Download Prerelease (new spreadsheet) instead of (old spreadsheet) I don't know if that would even matter
[2014-10-16 07:58:03] |
We still are not able to determine the problem. We are going to be releasing version 1202 which will have more logging. We want you to follow the procedure given in post #7 again with that version.
[2014-10-16 12:14:20] |
ok, is it ready now? Or when will the release happen?
[2014-10-16 14:28:35] |
1202 has been released. Update Sierra Chart with Help >> Download Prerelease.
[2014-10-16 14:45:58] |
Its still not loading, I will re-send my log again
[2014-10-16 14:46:33] |
Date rule based rollover from F.US.CLEN12 to next contract occurs at 2012-06-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEQ12 to next contract occurs at 2012-07-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEU12 to next contract occurs at 2012-08-20. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEV12 to next contract occurs at 2012-09-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEX12 to next contract occurs at 2012-10-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEZ12 to next contract occurs at 2012-11-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEF13 to next contract occurs at 2012-12-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEG13 to next contract occurs at 2013-01-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEH13 to next contract occurs at 2013-02-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEJ13 to next contract occurs at 2013-03-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEK13 to next contract occurs at 2013-04-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEM13 to next contract occurs at 2013-05-20. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEN13 to next contract occurs at 2013-06-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEQ13 to next contract occurs at 2013-07-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEU13 to next contract occurs at 2013-08-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEV13 to next contract occurs at 2013-09-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEX13 to next contract occurs at 2013-10-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEZ13 to next contract occurs at 2013-11-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEF14 to next contract occurs at 2013-12-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEG14 to next contract occurs at 2014-01-20. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEH14 to next contract occurs at 2014-02-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEJ14 to next contract occurs at 2014-03-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEK14 to next contract occurs at 2014-04-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEM14 to next contract occurs at 2014-05-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEN14 to next contract occurs at 2014-06-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEQ14 to next contract occurs at 2014-07-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEU14 to next contract occurs at 2014-08-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEV14 to next contract occurs at 2014-09-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEX14 to next contract occurs at 2014-10-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-16 09:43:31 Intraday data recording state for symbol F.US.CLEZ12 is set to pending. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEX14 for the date range from 2014-09-19 to 0. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-16. | 2014-10-16 09:43:31 Replay 1000.0X: F.US.CLEX14 [CBV] 2 Min #1 | Symbols used for continuous contract chart: | 2014-10-16 09:43:31 F.US.CLEN12 | 2014-10-16 09:43:31 F.US.CLEQ12 | 2014-10-16 09:43:31 F.US.CLEU12 | 2014-10-16 09:43:31 F.US.CLEV12 | 2014-10-16 09:43:31 F.US.CLEX12 | 2014-10-16 09:43:31 F.US.CLEZ12 | 2014-10-16 09:43:31 F.US.CLEF13 | 2014-10-16 09:43:31 F.US.CLEG13 | 2014-10-16 09:43:31 F.US.CLEH13 | 2014-10-16 09:43:31 F.US.CLEJ13 | 2014-10-16 09:43:31 F.US.CLEK13 | 2014-10-16 09:43:31 F.US.CLEM13 | 2014-10-16 09:43:31 F.US.CLEN13 | 2014-10-16 09:43:31 F.US.CLEQ13 | 2014-10-16 09:43:31 F.US.CLEU13 | 2014-10-16 09:43:31 F.US.CLEV13 | 2014-10-16 09:43:31 F.US.CLEX13 | 2014-10-16 09:43:31 F.US.CLEZ13 | 2014-10-16 09:43:31 F.US.CLEF14 | 2014-10-16 09:43:31 F.US.CLEG14 | 2014-10-16 09:43:31 F.US.CLEH14 | 2014-10-16 09:43:31 F.US.CLEJ14 | 2014-10-16 09:43:31 F.US.CLEK14 | 2014-10-16 09:43:31 F.US.CLEM14 | 2014-10-16 09:43:31 F.US.CLEN14 | 2014-10-16 09:43:31 F.US.CLEQ14 | 2014-10-16 09:43:31 F.US.CLEU14 | 2014-10-16 09:43:31 F.US.CLEV14 | 2014-10-16 09:43:31 F.US.CLEX14 | 2014-10-16 09:43:31 Replay 1000.0X: F.US.CLEX14 [CBV] 2 Min #1 | Waiting for historical downloads to complete with the IDs: 4, | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEN12 to next contract occurs at 2012-06-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEQ12 to next contract occurs at 2012-07-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEU12 to next contract occurs at 2012-08-20. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEV12 to next contract occurs at 2012-09-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEX12 to next contract occurs at 2012-10-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEZ12 to next contract occurs at 2012-11-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEF13 to next contract occurs at 2012-12-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEG13 to next contract occurs at 2013-01-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEH13 to next contract occurs at 2013-02-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEJ13 to next contract occurs at 2013-03-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEK13 to next contract occurs at 2013-04-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEM13 to next contract occurs at 2013-05-20. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEN13 to next contract occurs at 2013-06-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEQ13 to next contract occurs at 2013-07-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEU13 to next contract occurs at 2013-08-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEV13 to next contract occurs at 2013-09-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEX13 to next contract occurs at 2013-10-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEZ13 to next contract occurs at 2013-11-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEF14 to next contract occurs at 2013-12-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEG14 to next contract occurs at 2014-01-20. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEH14 to next contract occurs at 2014-02-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEJ14 to next contract occurs at 2014-03-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEK14 to next contract occurs at 2014-04-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEM14 to next contract occurs at 2014-05-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEN14 to next contract occurs at 2014-06-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEQ14 to next contract occurs at 2014-07-21. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEU14 to next contract occurs at 2014-08-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEV14 to next contract occurs at 2014-09-19. | 2014-10-16 09:43:31 Date rule based rollover from F.US.CLEX14 to next contract occurs at 2014-10-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLN12 for the date range from 2012-05-21 to 2012-06-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLQ12 for the date range from 2012-06-19 to 2012-07-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLU12 for the date range from 2012-07-19 to 2012-08-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLV12 for the date range from 2012-08-20 to 2012-09-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLX12 for the date range from 2012-09-19 to 2012-10-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-16 09:43:31 Intraday data recording state for symbol F.US.CLEZ12 is set to pending. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLZ12 for the date range from 2012-10-19 to 2012-11-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLF13 for the date range from 2012-11-19 to 2012-12-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLG13 for the date range from 2012-12-19 to 2013-01-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLH13 for the date range from 2013-01-21 to 2013-02-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLJ13 for the date range from 2013-02-19 to 2013-03-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLK13 for the date range from 2013-03-19 to 2013-04-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLM13 for the date range from 2013-04-19 to 2013-05-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLN13 for the date range from 2013-05-20 to 2013-06-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLQ13 for the date range from 2013-06-19 to 2013-07-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLU13 for the date range from 2013-07-19 to 2013-08-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLV13 for the date range from 2013-08-19 to 2013-09-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLX13 for the date range from 2013-09-19 to 2013-10-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLZ13 for the date range from 2013-10-21 to 2013-11-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLF14 for the date range from 2013-11-19 to 2013-12-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLG14 for the date range from 2013-12-19 to 2014-01-20. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLH14 for the date range from 2014-01-20 to 2014-02-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLJ14 for the date range from 2014-02-19 to 2014-03-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLK14 for the date range from 2014-03-19 to 2014-04-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLM14 for the date range from 2014-04-21 to 2014-05-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLN14 for the date range from 2014-05-19 to 2014-06-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLQ14 for the date range from 2014-06-19 to 2014-07-21. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLU14 for the date range from 2014-07-21 to 2014-08-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLV14 for the date range from 2014-08-19 to 2014-09-19. | 2014-10-16 09:43:31 Checking Intraday data file for symbol F.US.CLEX14 for the date range from 2014-09-19 to 0. | 2014-10-16 09:43:31 Checking Daily data file for symbol CLX14 for the date range from 2014-09-19 to 2014-10-16. | 2014-10-16 09:43:31 Replay 1000.0X: F.US.CLEX14 [CBV] #2 | Symbols used for continuous contract chart: | 2014-10-16 09:43:31 F.US.CLEN12 | 2014-10-16 09:43:31 F.US.CLEQ12 | 2014-10-16 09:43:31 F.US.CLEU12 | 2014-10-16 09:43:31 F.US.CLEV12 | 2014-10-16 09:43:31 F.US.CLEX12 | 2014-10-16 09:43:31 F.US.CLEZ12 | 2014-10-16 09:43:31 F.US.CLEF13 | 2014-10-16 09:43:31 F.US.CLEG13 | 2014-10-16 09:43:31 F.US.CLEH13 | 2014-10-16 09:43:31 F.US.CLEJ13 | 2014-10-16 09:43:31 F.US.CLEK13 | 2014-10-16 09:43:31 F.US.CLEM13 | 2014-10-16 09:43:31 F.US.CLEN13 | 2014-10-16 09:43:31 F.US.CLEQ13 | 2014-10-16 09:43:31 F.US.CLEU13 | 2014-10-16 09:43:31 F.US.CLEV13 | 2014-10-16 09:43:31 F.US.CLEX13 | 2014-10-16 09:43:31 F.US.CLEZ13 | 2014-10-16 09:43:31 F.US.CLEF14 | 2014-10-16 09:43:31 F.US.CLEG14 | 2014-10-16 09:43:31 F.US.CLEH14 | 2014-10-16 09:43:31 F.US.CLEJ14 | 2014-10-16 09:43:31 F.US.CLEK14 | 2014-10-16 09:43:31 F.US.CLEM14 | 2014-10-16 09:43:31 F.US.CLEN14 | 2014-10-16 09:43:31 F.US.CLEQ14 | 2014-10-16 09:43:31 F.US.CLEU14 | 2014-10-16 09:43:31 F.US.CLEV14 | 2014-10-16 09:43:31 F.US.CLEX14 | 2014-10-16 09:43:31 Replay 1000.0X: F.US.CLEX14 [CBV] #2 | Waiting for historical downloads to complete with the IDs: 4, | 2014-10-16 09:43:31 HD Request # 4 | Downloading Intraday chart data for F.US.CLEZ12 to the file F.US.CLEZ12.scid. Service: nymex | 2014-10-16 09:43:31 HD Request # 4 | Download start Date-Time: 2012-11-16 13:29:58.0 | 2014-10-16 09:43:31 HD Request # 4 | Using server: scdf2.sierracharts.com port 10149 | 2014-10-16 09:43:31 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-10-16 09:43:31 Socket (932) | Connected. | 2014-10-16 09:43:31 HD Request # 4 | Sending historical data logon request message. | 2014-10-16 09:43:31 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2012-11-16 13:29:58. Record interval: 0. Symbol: CLZ2 | 2014-10-16 09:43:32 HD Request # 4 | Decompressing data. | 2014-10-16 09:43:32 HD Request # 4 | Receiving Intraday data for F.US.CLEZ12 starting at 2012-11-16 13:29:58 | 2014-10-16 09:43:32 Socket (932) | Shutdown and closed. | 2014-10-16 09:43:32 The network socket for historical data has been closed. | 2014-10-16 09:43:32 HD Request # 4 | Received 1 record from 2012-11-16 13:29:58 to 2012-11-16 13:29:58 (0.0 seconds) and wrote 0 records for F.US.CLEZ12 | 2014-10-16 09:43:32 HD Request # 4 | Intraday download COMPLETE for F.US.CLEZ12. Completion time: 0s. Unique request ID: 4 | 2014-10-16 09:43:32 Real-time Intraday chart data file updates started for F.US.CLEZ12 | 2014-10-16 09:43:32 |
[2014-10-16 14:59:02] |
From what we can tell this should be working properly. Do both of the charts you are replaying show the message "Downloading Continuous Contract Data"? Or one of them. Or is it some other problem. When we tested the scenario of replaying 2 Continuous Futures Contract charts, we did not see a problem. Not sure why this is happening for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-16 14:59:41
[2014-10-16 15:04:59] |
Yes they both say that while I wait.
[2014-10-16 15:28:03] |
I am still unable to do any back testing
[2014-10-17 12:28:55] |
What is next?
[2014-10-17 13:18:36] |
We are still thinking about this. We will need to add more logging to determine the source of the problem. For now you can reduce the amount of days loaded in the chart to avoid loading data back to 2012. This should solve the problem temporarily. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-17 13:22:41
