Date/Time: Wed, 27 Nov 2024 20:43:23 +0000
TYX
View Count: 1592
[2014-10-09 02:56:41] |
rhovega - Posts: 279 |
Dear Sierra, Looking at $TYX with your data feed shows 0.005 minimum increments. $TYX moves in 0.001 increments. Is there a solution to this? TYX screenshot attached. Chart is set as: Price Display Format: 0.0001 Tick Size: 0.0001 Thank you |
[2014-10-09 03:02:50] |
We had a look at the data and the increment that we see is .01. How do you it moves in .001 increments? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-10 01:04:19] |
TYX is quoted as xx.xx. See the CBOE website: http://www.cboe.com/DelayedQuote/SimpleQuote.aspx?ticker=tyx. For reasons unknown to me some websites quote it as x.xxx (effectively dividing the quote by 10), while some others quote it as x.xx (effectively dividing the quote by 10 and eliminating the last digit). Through the CBOE feed I subscribed to through you I am receiving the quote as x.xx. Thus it is missing the last digit, which for an interest rate index is a very significant issue. |
[2014-10-10 01:05:15] |
The link I posted is saying "symbol not found". Simply type in TYX in the CBOE site that opens and you'll see it. Thank you.
[2014-10-10 03:05:25] |
We are an making an inquiry as to why the data is provided like it is.
