Date/Time: Wed, 12 Feb 2025 04:30:30 +0000
Resize text box via handles.
View Count: 1086
[2014-10-08 21:53:50]
User57562 - Posts: 98
Left click on a text box places 3 dots on each side, as if handles. However, those handles do NOT stretch/resize box & text.
User CAN move box.
Right click offers properties>options>uncheck global font> select font & size.
Why not simply drag handles, a very common operation in windows? (I have even programmed such myself.)
Date Time Of Last Edit: 2014-10-08 21:55:10
[2014-10-08 23:43:22]
This is not supported with text drawings.
[2014-10-10 17:03:30]
"This is not supported with text drawings."
Obviously true, which I was suggesting it to be added.
[2017-07-23 04:15:50]
GordonT - Posts: 6
How do we actually create a text box in SC? "Type Text" and "Stationary Text" tools is not what I'm looking for. I want to create a simple text box similar to the ones that SC engineers use when providing insight to SC tools and features.
[2017-07-23 06:00:55]
This is not supported if you are referring to a dialog type window.
Or any type of other window.
[2020-10-04 20:11:52]
User891422_YHW - Posts: 5
Yeah it would be very helpful to be able to adjust the text box size... Is that possible now or is that option still unavailable? Just asking becouse I see that the post is from 2014, I was googling how to adjust txt on Sierra and found this thread...
