Date/Time: Wed, 27 Nov 2024 20:43:08 +0000
I am unable to get chart data
View Count: 959
[2014-10-08 14:42:18]
User19552 - Posts: 3
I receive the following errors:
Unsubscribed from market depth data for ESZ4-CME | 2014-10-08 10:17:23
Requesting market depth updates for: ESH5-CME if supported. | 2014-10-08 10:17:23
Market Depth data has been rejected for symbol: ESZ4-CME. | 2014-10-08 10:17:23
Market Depth data has been rejected for symbol: ESH5-CME. | 2014-10-08 10:17:23
Unsubscribed from market depth data for ESH5-CME | 2014-10-08 10:17:38
Requesting market depth updates for: ESZ4-CME if supported. | 2014-10-08 10:17:38
Market Depth data has been rejected for symbol: ESH5-CME. | 2014-10-08 10:17:38
Market Depth data has been rejected for symbol: ESZ4-CME. | 2014-10-08 10:17:38
[2014-10-08 16:00:28]
We are running a test with Rithmic on our site to see if we can duplicate this.
[2014-10-08 16:08:54]
Are you still seeing the problem now? This is a Rithmic issue.
[2014-10-08 16:16:23]
A reboot of the computer fixed the problem.
[2014-10-08 16:39:36]
You should definitely not have to restart Windows for this.
A simple File >> Disconnect and File >> Connect to Data Feed would be all that is necessary.
We had several other users report this problem.
