Date/Time: Sat, 26 Sep 2026 22:08:14 +0000
Correct Session Times for Daily Chart
View Count: 1410
[2014-10-08 01:17:47]
buylosellhi - Posts: 60
I'm not seeing correct sessions on my daily charts. For example, if you take a look at the Bonds daily chart, it shows the current daily candle is still forming even though we have moved to next day's candle.
It should have started a new daily candle as of 1800 hrs New York Time.
How can I correct this ?
Thanks for your help
imageBonds.PNG / V - Attached On 2014-10-08 01:17:37 UTC - Size: 45.28 KB - 525 views
[2014-10-08 01:56:36]
This can be solved by following the instructions here:
https://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.6
Another quick solution to this is to select Edit >>Download Data for All Historical Charts at the end of the day when the new trading session begins.
This is explained here:
https://www.sierrachart.com/index.php?page=doc/helpdetails12.html#12.5
Date Time Of Last Edit: 2014-10-08 01:57:08
