Date/Time: Wed, 27 Nov 2024 20:38:15 +0000
Candlestick shadow colors
View Count: 1246
[2014-10-07 19:00:28]
User32803 - Posts: 18
Is there a way to make the color of candlestick shadows say white and the colors of the body green or red as appropriate.
[2014-10-07 20:55:59]
Yes. Refer to this page for instructions:
https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html
You will need to uncheck:
Global Settings >> Graphics Settings >> Other >> Color Candlestick High Low Using the Outline Colors
And set the colors as you require.
Date Time Of Last Edit: 2014-10-07 20:56:23
