Date/Time: Wed, 27 Nov 2024 20:45:07 +0000
Bug? Or Change Suggestion
View Count: 962
[2014-10-07 15:58:45] |
djcurcio - Posts: 236 |
When specifying a study Draw Style of "FILL" the Name Labels and the Value Labels are omitted. To get name and value labels for the study by duplicating the study with a "LINE" Draw Style. This uses unnecessarily additional CPU resources. Suggest that Name and Value labels be displayed if cheked for all draw types. Thanks |
[2014-10-07 16:04:43] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-07 16:58:08] |
Enclosed is the chart file. Note that the SMA Fill Bottom does NOT display the Name and Value Labels. Thanks |
For Sierra.cht - Attached On 2014-10-07 16:57:04 UTC - Size: 28.98 KB - 331 views For Sierra.cht - Attached On 2014-10-07 16:57:59 UTC - Size: 28.98 KB - 394 views |
[2014-10-09 04:20:00] |
This is an improper use of Fill Draw Styles because you have not used a pair of them. Nevertheless, a label is shown: http://www.sierrachart.com/image.php?l=1412828363281.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
