Date/Time: Wed, 27 Nov 2024 20:30:33 +0000
TF data missing on CQG feed
View Count: 1218
[2014-10-07 15:57:16] |
User48122 - Posts: 7 |
I have a gap in TF data on AMP CQG feed (F.US.TFEZ14). I tried to reload the data, even delete and download it again, without success. It is updating from the time I started Sierra, but I can not backfill the gap. Interestingly, NinjaTrader connected to the same data feed is working fine. |
Sierra TF data gap-cqg feed-2014-10-07_113156.png / V - Attached On 2014-10-07 15:56:35 UTC - Size: 69.04 KB - 374 views |
[2014-10-09 02:32:16] |
We know about this and this is not within our control. AMP has been notified of it. As of this moment, the historical data is now up to date . So you can try re-downloadingby right clicking on the chart before the missing data and select Delete and Download Data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-09 02:33:20
[2014-10-09 07:53:44] |
Thanks. I just noticed another gap in TF data, between New York time 22:16 (8 Oct) and 03:20 (9 Oct = today), which I can not get rid off by re-downloading. I will contact AMP then in hope that they resolve this issue. |
russel data gap cqg feed tick chart 2014-10-09_034726.png / V - Attached On 2014-10-09 07:53:02 UTC - Size: 77.13 KB - 395 views |
[2014-10-09 08:09:27] |
Please do not contact AMP about this. We will handle the contact to them about this. More than likely whoever you contact about it, would not have an understanding about it. And it will only confuse things more.
