Date/Time: Wed, 27 Nov 2024 20:51:04 +0000
Trial & Chartbook/Chart Templates
View Count: 909
[2014-10-07 04:42:47] |
User78442 - Posts: 260 |
Hi I'm due to finish a trial in 2 days. I want to renew the service in 2 weeks after a holiday. Will my settings still be saved or do I need to archive them? thanks..
[2014-10-07 05:11:01] |
Your settings will remain. They will not be lost unless you were to delete Sierra Chart from your system.
