Date/Time: Wed, 27 Nov 2024 20:41:55 +0000
Pivot Points
View Count: 1336
[2014-10-07 01:46:18] |
Johnny - Posts: 99 |
Hi, there's an issue with the pivot points study. Even though I have the option "Auto skip period of no trading" set on YES, pivot points are not calculated for the first bar of the session after the weekend. |
[2014-10-07 01:53:39] |
We need to know all of the Input settings of the Pivot Points study that you have set and the exact name of the specific Pivot Points study you are using. We also need to see an image of the chart. Here are the instructions to post an image: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-07 17:47:15] |
The study name is "Pivot Points - Variable Period" and here are the settings: Time Period Type: Minutes Time Period Length: 5 Formula Type: 0 Minimum Required Time Period as %: 25 Round to Tick Size: No Display Debugging Output: No Forward Project Pivot Point Lines: No Number of Days to Calculate: 1000 Auto Skip Period of No Trading: Yes Number of Forward Project Bars: 20 Please see the attached images. |
CL.20141100.CME_NY 5 Min #10 2014-10-07 19_35_07.130.png / V - Attached On 2014-10-07 17:36:39 UTC - Size: 104.74 KB - 343 views CL.20141100.CME_NY 5 Min #10 2014-10-07 19_35_24.088.png / V - Attached On 2014-10-07 17:36:47 UTC - Size: 102.61 KB - 328 views CL.20141100.CME_NY 5 Min #10 2014-10-07 19_36_32.135.png / V - Attached On 2014-10-07 17:36:53 UTC - Size: 107.85 KB - 354 views TF.20141200.ICE_IN 5 Min #9 2014-10-07 19_31_53.478.png / V - Attached On 2014-10-07 17:37:04 UTC - Size: 98.6 KB - 356 views TF.20141200.ICE_IN 5 Min #9 2014-10-07 19_32_33.751.png / V - Attached On 2014-10-07 17:37:57 UTC - Size: 99.19 KB - 350 views TF.20141200.ICE_IN 5 Min #9 2014-10-07 19_33_13.297.png / V - Attached On 2014-10-07 17:38:03 UTC - Size: 100.85 KB - 355 views |
[2014-10-09 02:13:31] |
We only needed to see one image of the chart. The other images are unnecessary and we did not look at them. It only takes more of your time unnecessarily and increases the amount of time before you get a response. The basic problem is that the time period setting for the study is 5 minutes and because it is very small, the study does not look back a large number of periods to get to available data. This is how it is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
