Date/Time: Thu, 28 Nov 2024 00:33:20 +0000
question about dll's with the same methods
View Count: 1043
[2014-10-07 00:59:12] |
onnb - Posts: 662 |
hi - the ui sometimes freezes when i go to add a custom study. i'm pretty sure its related to one my dlls but am not sure. thought the scenario below which i have during testing could be the cause. i have 2 dlls in the data directory that have the exact same exported study functions - each dll has a different physical name and a different SCDLLName name. so when i go to add custom study, i see both of them. could this in any way you can think of cause the ui to freeze at times? |
[2014-10-07 01:56:22] |
No, this cannot be the cause. There must be something else causing this. But we do think it is caused by a DLL.
[2014-10-07 04:27:09] |
onnb - Posts: 662 |
related to this, does the study function always get called on the main application thread? in the debugger it seems like so
[2014-10-07 05:11:24] |
Yes it does. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-23 21:21:41] |
onnb - Posts: 662 |
Yes it does.
following up on this, just to make sure I understand - this implies that if I define a global variable in my study code, that global variable can be accessed from the study in a thread safe manner without requiring any special locking around section that access this variable - right? |
[2014-10-24 05:14:59] |
Yes, this is correct.
