Date/Time: Wed, 27 Nov 2024 20:29:07 +0000
Sierra Chart Versions problem
View Count: 935
[2014-10-06 21:53:41]
AC94882 - Posts: 8
Hi support,
Q1:
I have two computers:
One with Sierra chart ver 1187, and the other with 1198.
I am running the same ACSIL code on both on of them.
The code needs to draw some rectangles on the chart.
1187 - works perfect!
1198 - the rectangels are duplicated to other places on the chart, (which is a bug!)
WHY??
Is there is a way to download ver 1187 instead of 1198 (which is newer one)?
Did you heard about other differents between the version?
Q2:
I am saving my chart to *.cht file. Is it possible to import this file to my other computer, and load it up? The Sierra chart always says there is a problem with the chart file...
Thanks,
Ariel
[2014-10-06 22:33:49]
1. We need a simple code example to duplicate this problem.
2. What is the specific error message you see in the Message Log when opening that Chartbook?
