Date/Time: Wed, 27 Nov 2024 20:33:41 +0000
Horizontal Line - Drawn only for one trading day
View Count: 946
[2014-10-06 18:26:48] |
User787778 - Posts: 140 |
In a chart which goes back two years,I need to draw specific horizontal lines, which are different each day, but are only valid for that respective day and must not to extend, to the right, beyond the close for that day. Each line must start at the open and finish at the close for that day using the tool menu. Thanks in advance. |
[2014-10-07 01:58:23] |
We recommend manually drawing them with the Line tool: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#LineRay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
