Date/Time: Fri, 22 Nov 2024 13:01:56 +0000
Determining P/L ratios in a chart
View Count: 1578
[2013-05-12 08:57:25] |
cfuture - Posts: 67 |
I would like to know if it is possible to see the possible P/L after indicating possible entry, stop, and target prices in a chart?
[2013-05-13 23:06:16] |
Have a look at the Tools >> Reward/Risk tool.
