Date/Time: Wed, 27 Nov 2024 20:34:09 +0000
Data not stored correctly
View Count: 1152
[2014-10-06 07:54:52] |
Kiwi - Posts: 375 |
FYI. When using IB 5 second data, and an Intraday Data Storage Time other than 5 seconds, the HL and C data are correctly stored but the O is not. http://i.imgur.com/Aq67tT4.png Date Time Of Last Edit: 2014-10-06 07:55:06
[2014-10-07 07:26:46] |
We will look into this.
[2014-10-07 09:12:04] |
We found the problem and corrected this.
