Date/Time: Wed, 27 Nov 2024 20:37:45 +0000
moving SC to new device
View Count: 1003
[2014-10-06 02:49:11] |
GCAdmin - Posts: 35 |
I am moving SC to a new computer. I have copied the Data folder over yet my toolbar, tool configs and other global settings are not copied over. How can I get all of my previous settings copied over to the new install? |
[2014-10-06 06:53:18] |
tobi - Posts: 351 |
Have a look here: http://www.sierrachart.com/index.php?l=doc/helpdetails15.html |
[2014-10-06 07:15:39] |
You need to refer to help topic 15 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
