Date/Time: Thu, 06 Feb 2025 19:23:16 +0000
Volume by Price settings for 6E contract
View Count: 1475
[2014-10-05 19:32:34] |
bwalks123 - Posts: 122 |
How do I get the Volume By Price set up correctly to show volume at the .00001 tick level for my range charts? I have attached a range chart set to .00001 for both the Price Display Format and Tick Size in the chart settings and have the Volume by Price Study set to 1 for Ticks Per Volume Bar. Seems that I can only get volume to show at the .0001 levels and I am wanting all the volume in between each tick. http://www.sierrachart.com/image.php?l=1412536973703.png |
[2014-10-05 19:55:41] |
How would this be possible when the 6E has a tick size of .0001?
[2020-05-07 23:28:44] |
User404901 - Posts: 11 |
I have tried changing to the new 0.00005 tick size and cannot get it to chart or display the 1/2 tick value. Any suggestions? Data feed is CQG thank you
[2020-05-08 04:07:03] |
This is not making sense. That is the default Tick Size. You just need to follow the instructions here to apply that if it is not already: Global Symbol Settings: Applying Global Symbol Settings to Existing Intraday Chart This will also update the Price Display Format which might not be correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-08 04:12:00
[2020-05-08 10:33:42] |
When I go to Global Symbol Settings and view the correct symbol (F.US.EEU) it is defaulted to Price Display Format 0.0001 and tick size 0.000100. Can I change it here? thank you
[2020-05-08 11:24:34] |
This is the E7 contract. Therefore, the tick size cannot be made smaller.
