Date/Time: Wed, 27 Nov 2024 20:49:02 +0000
Request for Study - Invert
View Count: 1561
[2014-10-04 14:50:37] |
djcurcio - Posts: 236 |
Would be very useful to have a Study that multiplies the input study by -1. Thanks |
[2014-10-04 17:32:21] |
PTG - Posts: 57 |
You mean this ? http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s189 EDIT no you don't. EDIT2 yes you might. Select Settings and Inputs - Based on to be the study you'd like to multiply. Date Time Of Last Edit: 2014-10-04 17:44:27
[2014-10-06 08:11:21] |
Have a look at Study Subgraph Multiply: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s260 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
