Date/Time: Wed, 27 Nov 2024 20:47:09 +0000
Coffee...How to prevent gaps appearing at end of day and start of next morning?
View Count: 1871
[2014-10-04 08:31:55] |
User78030 - Posts: 6 |
http://www.sierrachart.com/image.php?l=1412410881351.png |
[2014-10-04 10:18:12] |
Sorry I forgot to write the message. This is the 5 Min chart for Coffee Can you spot the 5 dashes after the 12.25 time bar and then the resumption bar next morning at 3.15 This may affect my studies and as a result I do not want gaps. This applies to the 1 min chart as well http://www.sierrachart.com/image.php?l=1412417824235.png |
[2014-10-04 11:17:32] |
User11942 - Posts: 298 |
You may want to set your session times according to the contract trading hours. https://www.theice.com/products/15/Coffee-C-Futures |
[2014-10-05 00:13:00] |
You need to uncheck Chart >> Chart Settings >> Advanced Settings >> Include Columns with No Data. If that does not help, then: What Data or Trading service are you using or do you wish to use? See this page for the list: http://www.sierrachart.com/index.php?page=data.php&CAID=def Or, select "Global Settings >> Data/Trade Service Settings". What is the "Service" at the top left set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-05 00:13:14
[2014-10-05 10:12:14] |
The service box is set at " Service (Trading) I tried what you instructed but it dosen't get rid of the incorrect dashes. I trade with Transact |
[2014-10-05 18:37:25] |
We have looked at the TransAct data for this futures contract and we do see bar values repeating at the same price at the time you mention. What you can do in this case is use the Session Times to filter this data out: http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php You will want to set the Start and End Times so that it does not include the time range of the flat bars where there is no trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
