Date/Time: Wed, 27 Nov 2024 20:51:28 +0000
Study Subgraphs Add --outputs skipping/missing
View Count: 975
[2014-10-03 18:45:12] |
Leo33 - Posts: 73 |
I'm using Study Subgraphs Add to add together some Time and Sales Volume studies. The output doesn't 'lag' but it does 'skip' ie some output values don't appear. They do appear on a Recalc. Other studies seem to be ok, but I can't be sure. I'm wondering if you might have any ideas to trouble shoot? [might Sierra 'deliberately' skip if a calculation is not keeping up with the real-time data?] thanks, |
[2014-10-06 08:12:40] |
Without knowing the details of the study interdependency, we suspect this has something to do with study calculation precedence/order: http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyCalculationPrecedence Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
