Date/Time: Thu, 24 Sep 2026 10:10:22 +0000
Help with Modification Default Study .dll?
View Count: 1332
| [2014-10-03 12:06:20] |
| User51760 - Posts: 108 |
Hello Support Team, since I do not succeed in modifying the default Inside Or Equals Bar study I ask for some help: I need an Inside Or Equals Bar Study where the inside bar is defined as its Open and Close inside or equal to the previous bars High and Low. Either I would be very happy Sierra Chart adding such a study or somebody out there could help me with building it. Maybe it already exists? Thank you for your consideration, Best, Chris |
| [2014-10-04 04:23:07] |
| vegasfoster - Posts: 444 |
Try this
| [2014-10-04 07:05:09] |
Hello vegasfoster, fantastic! That does exactly what I need. Thank you very much for letting me use the .dll and for your help. Wonderful Support Board... Best, Chris |
| [2014-10-07 03:23:28] |
This will be part of User Contributed Studies in the next release.
| [2015-07-20 22:50:07] |
| User10023 - Posts: 3 |
Where do I find this study?
| [2015-07-20 23:00:34] |
Please disregard. I found it.
