Date/Time: Wed, 27 Nov 2024 18:43:21 +0000
Cumulative Delta Volume Bars not reseting at start of trading day
View Count: 939
[2014-10-03 03:10:00] |
rhovega - Posts: 279 |
Instrument: ESZ14 Chart type: 3 minute bars Session: starts 163000 ends 092959 Study: CD Volume Bars Issue: have study setup to Reset at start of trading day, but it does not reset Example: refer to attached chart. CD starts at ~-33,000 Please tell me how can I fix this problem? |
CD not reseting.png / V - Attached On 2014-10-03 03:09:45 UTC - Size: 90.7 KB - 333 views |
[2014-10-03 07:15:50] |
We are currently looking into this. We may need to get your Chartbook. Give us a couple of hours.
[2014-10-03 09:12:23] |
Something is not set right in the chart settings or with the study input. Also are you using the built-in Cumulative Delta Bars study. It works fine for us: http://www.sierrachart.com/image.php?l=1412327476770.png We have attached our Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
CumulativeDeltaResetExample.cht - Attached On 2014-10-03 09:12:20 UTC - Size: 38.33 KB - 486 views |
