Date/Time: Wed, 27 Nov 2024 18:47:19 +0000
[User Discussion] - highlight entired background once EMA cross over SMA
View Count: 1315
[2014-10-02 21:38:39] |
User35749 - Posts: 32 |
Dear Sir or Madam: I know how to highlight a background once EMA15 cross over SMA50; however, I just wonder can I highlight the background as long as EMA15 cross below SMA50 (one color) and EMA15 cross above SMA50 (different color background highlight)? Thanks, Van |
[2014-10-02 21:51:30] |
Since you want to use two different colors, you need to use two instances of the Color Background Based on Alert Condition studies. One for each condition and color.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-02 21:51:40
[2014-10-03 21:40:55] |
How can I highlight an entire background as long as EMA15 below SMA50? Thanks!
[2014-10-03 21:47:04] |
You could only do this with ACSIL by changing the background color of the chart. Not using the Color Background study.
[2014-10-03 22:11:20] |
Sawtooth - Posts: 4120 |
You can do it with the Spreadsheet Study study, using very simple formulas: -Add the Spreadsheet Study study, give it a name in the Spreadsheet Name field, and set the Chart Region to 1. -Set the Draw Style of K(SG1) and L(SG2) to Background, and set each subgraph to it's own color -Put these formulas in these cells: Cell K3: =$AA$3>$AC$3 Cell L3: =$AA$3<$AC$3 This assumes the MAs are at the top of the Studies to Graph list, so that their output is in columns AA and AC. You can also edit the formulas to reference different columns. |
