Date/Time: Wed, 27 Nov 2024 18:50:50 +0000
Spreadsheet for Trading. Usable columns for static calculations
View Count: 866
[2014-10-01 23:05:19]
CMG - Posts: 179
Hi There,
In the spreadsheet for trading which other columns apart from columns "I" and "J" can be used for static or constant calculations.
Thanks,
[2014-10-02 01:10:04]
Sawtooth - Posts: 4120
Column H is open for this purpose.
I'd avoid columns I and J because SC might populate cells in newer versions. However, rows 1 and 2 are safe in I and J.
Also, row 1 is usable from E1 to Z1, and up to BR1 if you set the Number of Formula Columns to the max of 60.
[2014-10-02 15:23:20]
You can use any empty column as long as it will not be used in the future by studies that you may add to the chart.
Avoid using I and J.
