Date/Time: Mon, 16 Sep 2024 19:30:00 +0000
mid stream Plan upgrade
View Count: 881
[2014-10-01 21:48:30] |
User57562 - Posts: 98 |
How might I add $13 to my Sep 24 $27 to reach pkg #5? In other words, will added pmt be merged or confused? |
[2014-10-01 21:55:13] |
You do not need to do this. You can change your service package here: https://www.sierrachart.com/usercp.php?page=ChangePackage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
