Date/Time: Wed, 27 Nov 2024 18:55:38 +0000
One Data Feed two charts
View Count: 882
[2014-10-01 20:40:49] |
User20702 - Posts: 13 |
Can I run two charts off one data feed? Two charts in the same chartbook that is? Thanks Dave |
[2014-10-01 20:43:00] |
Yes. This is no problem. Open whatever charts you need through File >> Find Symbol.
